will 35's fit my stock 97 f350? - Ford Powerstroke Diesel Forum
Old 11-16-2010, 02:40 PM
found good deal on craigslist, rims are 17's and tires are 35 bfg all terrains has anyone run them on stock truck are they gunna fit rub, rub alot, rub a little let me know what your running for tire size on you stock strokes
Old 11-16-2010, 04:41 PM
I don't know other than to say you'll probably need to know the backspacing/offset of the rim before anyone can answer that question accurately. A difference as small as a quarter inch can make a difference in clearance.
My research on this board tells me on stock rims, on a stock 4x4, 285/75R16 (32.8 X 11.2) will fit without rubbing, but 305/70R16 (34.0 X 12) will rub springs at full lock on stock wheels.
Old 11-16-2010, 06:02 PM
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
When I had 35's on my truck I had the trim the front bumper a bit but the rub on the leaf spring at full lock. My 305/70/16s dont rub one bit. Even on stock rims, but the tires also arent new. I'm putting some 35's on tommarow with my 16x8 rims and will get back to you.
Old 11-17-2010, 08:10 AM
Feedback Score: 5 reviews
4.5" BS..shim out the bumper or do a RS kit with SD springs..will clear and have a much better ride quality
