injector code??? - Ford Powerstroke Diesel Forum
Old 11-15-2010, 05:53 PM
injector code???
how do i know what injector code i have? truck is a 97
Old 11-15-2010, 07:04 PM
When you say code what exactly do you mean? DTC, Serial #. part #, Im just curiouse i might be able to help
Old 11-16-2010, 01:30 AM
like if its the aa or ab.. i dont know a whole lot about these
Old 11-17-2010, 10:43 AM
AB injectors are split shot and AA are not. since your truck is a 97 i would believe they are the split shots but i wouldnt assume. if you can, see if you can the part numbers on them.
Old 11-17-2010, 10:48 AM
Only CA emissions trucks got AB's.
To tell if you have split shots (AB) or singles (AA) look under the turbo. If there is a big black disc on the fuel pump you have AB's. If not you have AA's. Or just pull the valve cover and look at the injectors, they will say either AAxxxxx or ABxxxxx right on top.
