Gutting the Cat, - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-15-2010, 03:15 PM Thread Starter
Gutting the Cat,
Ok, so the truck has 296k miles, and some stage 1 injectors. I don't have the extra for a down pipe right now, but it seems gutting the cat would be free. Is it worth the effort? Any tips from those that have done it?
thanks in advance
Bill
loudmouth is offline
post #2 of 8 Old 11-15-2010, 09:01 PM
well from the engine to the tip is all exhaust pipe on mine completely straight all the way out no cat no muff. if you have a few buck to spend on a couple feet of pipe to feel the gap where the muffler and cat go id do it even if you keep it stock circumference. probably looking 40-50 bucks max at a muffler shop. i dont know how much if any performance i got of it but it sounds sweet as h e double hockey sticks
zombiediesel is offline
post #3 of 8 Old 11-16-2010, 02:24 PM
95ef2fiddy's Avatar
just go to napa and get u some 3inch pipe and some clamps
1997 f250 7.3
regular cab
tw chip
3 inch dp
4 inch cat delete
5% tint
glow shift gauges
6 inch cat stack
completely rebuilt kp d60
3 inch rsk
24s
38s
zf5 swap
southbend clutch
d66 turbo
4 inch skyacker springs
7 inch rear block
traction bars
bdp complete fuel system. (bowl delete and elec pump)
beans stage 2 injectors
intercooled
95ef2fiddy is offline
post #4 of 8 Old 11-16-2010, 02:30 PM
Soot_Life's Avatar
yes it helps... the cat doesnt really want to come off tho iwill wan you the dp bolts are practically welded on and the clamp towards the rear has formed the overlapping pipes toone another...i think the factory exauhst is 3 1/4 if my memory serves me right....
if you can get it off punch it out. if you cant cut it behind the bolts weld and clamp..
97 supercab 4x4: work truck. Reallly Loud stereo (16 speakers, none visable), 20's/35s, 6637, straight piped.
99vette: stock.
89crx, working on a idea that involves a 454 bigblock, 2.5tons, and boggers.
Custom built 12' jon boat: yea its got a 50 horse jet drive.
Soot_Life is offline
post #5 of 8 Old 11-17-2010, 08:45 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
Big difference when I did it and a Tymar intake at the same time..3mpg's! Thats with the stock exhaust system...I was very surprised at the difference in being able to pull hills faster afterwards.
CT Performance, Inc. is offline
post #6 of 8 Old 11-18-2010, 04:38 PM Thread Starter
Hope to be able to get this done tomorrow, a call to an ol buddy that runs a muffler shop, 30$ and he'll cut at the cat and replace past the muffler,
post #7 of 8 Old 11-18-2010, 05:05 PM
So straight pipe from down pipe to tip or leavin in muffleri suggest cutting the mufler the sound will make you pitch a tent
post #8 of 8 Old 11-19-2010, 01:59 PM Thread Starter
DONE, Cut it just past the flange for the converter, 3" straight dumped just before the axle, Sounds Great! I hope I can find some mileage in it also!
