Help! - Ford Powerstroke Diesel Forum
post #1 of 124 Old 11-14-2010, 09:14 PM Thread Starter
1995f350's Avatar
Help!
Got a few questions About my 1995 psd f350 got a concern about white smoke coming out of the hood when i try and fire her up on a cold morning.... whats the reason do you think?
1995f350 is offline
post #2 of 124 Old 11-14-2010, 09:46 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
probably the up pipe donuts leaking. we have a 94.5 that does that to. happens really bad when its super cold out
Trucks and parts............
kanuck15 is offline
post #3 of 124 Old 11-14-2010, 10:23 PM Thread Starter
1995f350's Avatar
Ok what would be the soloution thanks
1995f350 is offline
post #4 of 124 Old 11-14-2010, 10:51 PM
kanuck15's Avatar
Quoted: 10 Post(s)
new uppipe gaskets. but this is also a sign of low compression. is there any soot on the metal heat shielding back by the turbo?
kanuck15 is offline
post #5 of 124 Old 11-14-2010, 10:53 PM Thread Starter
1995f350's Avatar
have to look Im farely new to the 7.3 lack of compression mean its doomed?
1995f350 is offline
post #6 of 124 Old 11-15-2010, 05:51 AM
ridiculously_necessary's Avatar
it could be a loose or shot turbo DP clamp. thats my issue.
not necessarily. if your lucky you have bad injector o-rings.
worst case is a dusted motor. does your air filter box have plastic or metal screws on top?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #7 of 124 Old 11-15-2010, 06:06 AM Thread Starter
1995f350's Avatar
there plastic its a K@n filter box if farely new to this modle of psd so its chineese to me but im stuck no it wont start and im late for work! lol
1995f350 is offline
post #8 of 124 Old 11-15-2010, 06:16 AM
can you jump the glow relay with a screwdrive or jumper cables? its to the left of the fuel bowl, the two large posts. jump it for about 15 or 20 seconds or so then try and start. if your relay is bad it will start.
is the K&N box an aftermarket box entirely or jsut a K&N filter in the stock box?
the stock box that had plastic screws was recalled becuase it allowed dirt past the air filter and would dust motors. hopefullty thats not your problem.
-Matt
DIY 6637
Marinco Mod
post #9 of 124 Old 11-15-2010, 06:33 AM Thread Starter
1995f350's Avatar
To get to the relays u open the engine cover and the relay is to the left hand side right?
1995f350 is offline
post #10 of 124 Old 11-15-2010, 06:38 AM
you are correct.
-Matt
DIY 6637
Marinco Mod
