Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L General Powerstroke Discussion
Old 05-02-2006, 06:42 PM
fordcummins fordcummins is offline
Send a message via AIM to fordcummins
Axle seal Question
Hello all,
Great site. Looks awefully familiar to another site I'm a member of. At any rate, I was curious as to if I could get a part number for the rear axle seals on my 1994 f350. It originally came with a 351. It of course has 4 wheel drive. Any input would be great.
Thanks,
JJ
P.s. The axle that is in the truck is a Dana 70, correct? I'm pretty sure the 80 has it stamped on the pig somewhere.
Old 05-02-2006, 06:46 PM
mschn99 mschn99 is offline
Banished
Originally Posted by fordcummins
Hello all,
Thanks,
JJ
it is probably a ford 10.5 inch rear end........they only used the danas on the bigger trucks even in the newest ones...........look at the tag on one of the diff bolts....it will say S????(example would be S682T) on top.......the lower line will be the gear ratio (3 73 or 3L 73 as an example....the L means posi) and then after the gear ratio it will probably say 10 5.....which means its a for 10.5 inch rear end (full floater no matter what)......with this info you should be able to get he part from any parts house or dealer......Marc
Old 05-02-2006, 06:50 PM
Banished
and one more thing....welcome to the site...the other site you reffered to was one of our sister sites. LEM....or andy to some guys....has four sites he runs......the cummins, powerstroke, duramax, and nissan titan sites are all essentially the same type of site run by the same guy.....Marc
Old 05-03-2006, 05:25 AM
Ah ha!...makes sense now. At any rate, thanks for your help marc. I think I've seen you over there too. Nice site again!
-JJ
Old 05-03-2006, 06:08 AM
Banshee34 Banshee34 is offline
Ms. Independent
BTW..... WELCOME!!!!!!!!!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
