Rear Fuel Tank ?'s - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-14-2010, 06:55 AM Thread Starter
TxAG'97's Avatar
Rear Fuel Tank ?'s
Gas Tank, 33 Gallon Plastic 90-96
Last week I had a subcontractor’s work truck jump out of gear, roll down the hill, and collide with mine pushing it into the double wide job trailer we are working out of. There was not much damage done to my truck but it will go visit the body shop for minor stuff – thanks to the ranch hand bumpers. Can’t say the same for the exterior wall of the trailer – it pretty much caved in the entire side.
While my truck visits the body shop for rear end work I thought of getting the rear fuel tank replaced with the larger 33 gallon bronco tank. I found the Poly tank on the attached link – is that what I should go with?
I plan on buying everything and taking it to the body shop and giving them all the parts to do the install for me. What else do I need or should look at for this mod?
I did a search without finding a lot – thanks for any info.
1997 F250 XLT Crew Cab 4x4 Short Bed
Tymar Intake, 6 pos. TW Chip, Stage 1's, BTS
3" DP 4" w/a muff but w/out a kitty & 5" tip
TSM Rear Disc Brake Conversion, Viper Keyless Entry & Remote Start
King Pin Dana 60, SD rear B codes, Bilsteins 4600
Ranch Hand Replacement Front & Rear Replacement Clear Headlights
Ruff Tuff Seat Covers, Westin Nerf Bars
16x10 Pacers W/315 75x16 Duratracs
Most importantly
I am the proudest member of the
Fightn' Texas Aggie Class of '07 Gig'em
TxAG'97 is offline
post #2 of 4 Old 11-14-2010, 09:48 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
you need to modify the bronco sending unit. ours arent deep enough for it.
Trucks and parts............
kanuck15 is offline
post #3 of 4 Old 11-15-2010, 03:08 AM Thread Starter
TxAG'97's Avatar
38 Gal. Steel Tank,Pick-Up
The sending units are not interchangeable? What would I need to do to the existing one? Are there any disadvantages to going with the poly tank vs the steel one? I noticed that the 38 gallon steel tank is $375 and the poly is only $145. I’m not sure the extra 5 gallons is worth $230.
Just making sure I don’t buy something that won’t work – thanks for the help.
Most importantly
TxAG'97 is offline
post #4 of 4 Old 11-15-2010, 07:43 AM
kanuck15's Avatar
Quoted: 10 Post(s)
you can use your sending unit but you would have to extend the pick up tube to meet the tank depth along with the gauge bouy
kanuck15 is offline
