DP installed
771 views 7 replies 2 participants last post by  kanuck15
#1 ·
#3 ·
If it helps anyone that will be doing this in the future, to get the firewall pushed back I used a scissors type jack out 6th gen honda accord, It was small enough to fit in and just strong enough to get the job done. I had though about buying a hydraulic port-o-power but did not want to spend the money for it.
#7 ·
I had just used the sawzall to cut it in half. But it was the last inch of the upper half that was a problem when pulling out the top. Now there is clearance to pull entire DP out from the top in one piece
