Spring perch width?? - Ford Powerstroke Diesel Forum
Old 11-06-2010, 08:11 PM
Question Spring perch width??
Does an F350 rear axle have a narrower spring perch width than an F250 ????
Old 11-07-2010, 09:29 AM
drives a ranger
Send a message via AIM to kanuck15
nope. its all the same 250 and 350
Old 03-13-2011, 02:06 PM
spring perch
Hi, not to muddy up the waters any but my son wants to put f-350 dually axle
under his f-250,the problem we are having is the f-250 is a 95psd and the dually rear end is a 97 f-350 the spring perches are narrower then the f-250.
Also the perches are narrower on the f-350 then on the f-250,its as if we will
have to remove the perches off of the f-250 to keep the same spring width
pad. now this info is for the simple fact that i am looking at both rear ends
side by side,thanks
Old 03-13-2011, 03:41 PM
Electrical Ogre
If the DRW rear end was from a cab/chassis it will have a different perch spacing. The pickup versions will be the same.
