oil leak front of motor - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-02-2010, 05:51 PM Thread Starter
dogrider's Avatar
I have always had a small leak at front of motor. It was a drop or two a week but for the past few days it starting to really leak(BAD). It looks like its coming down at front of oil pan or above it a belt pulley. Should I use a stop leak or something like that until I get it fixed. Anyone have problems with theres leaking there.
Thanks Chris........
dogrider is offline
post #2 of 6 Old 11-02-2010, 05:59 PM
Bad Night's Avatar
Quoted: 3 Post(s)
Probably a front seal leaking . You have to pull the harmonic balancer and then it's a piece of cake .
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #3 of 6 Old 11-02-2010, 06:03 PM Thread Starter
dogrider's Avatar
How hard is it to pull harmonic balancer?
dogrider is offline
post #4 of 6 Old 11-02-2010, 06:08 PM
Bad Night's Avatar
Quoted: 3 Post(s)
Not too bad , you can rent the puller / installer from autozone (or where ever ) . It is only pressed in place and then one big bolt in the center . Note , do not start engine with balancer removed . The seal is just pressed in .
post #5 of 6 Old 11-03-2010, 08:09 AM
ridiculously_necessary's Avatar
also check your oil cooler, could be leaking at the gasket. and your hpop res gasket
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #6 of 6 Old 11-03-2010, 07:11 PM Thread Starter
dogrider's Avatar
Isnt the oil cooler line going into the radiator. And where would I look for the leak at hpop. Everything on upper front looks clean. Thanks Chris
dogrider is offline
