water pump install - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-01-2010, 06:03 PM Thread Starter
FiberglassEater's Avatar
Send a message via AIM to FiberglassEater
Question water pump install
has any-1 installed a water pump on our trucks ? if you did and have any tips please let me know.... never done this on a 7.3 before.
97 f-350 cc lb 4x4
FiberglassEater is offline
post #2 of 3 Old 11-02-2010, 05:55 AM Thread Starter
97 f-350 cc lb 4x4
post #3 of 3 Old 11-02-2010, 06:51 AM
zROCK's Avatar
Pull the rad makes it so much easier to work on. While you have the rad out give it a good flush you will be amaized on how much crap you get out of the bottom. While you have it out and the system emptie you should go to napa and get the coolant filtr base and install that while your in their. Just ordered mine yesterday hoping to install tomorow. I had to put a light bead of silicon around the thermostate hosing to keep it from leaking. Also had to replace the lower rad hose as the wire inside had rusted to the rad and pulled out.
zROCK is offline
