well, now what?!
as some of you guys know, i had my 95 psd that had a no start problem. well it turns out it was the icp. now it idles and quits then restarts. then i will give me a check engine light and go into a limp mode. running but no power. could i still have air in the hpop system or is it something else? i can turn it off and restart it and cel goes out and it runs normal. this happened three times. on the way home i tried to make it come on and it didn't.
random sucks. im going through a similar situation.
was the ipr replaced as well? i recall the thread but not all the details. and anyone hear you with AE? |
no i didn't change the ipr (it didn't scan as being bad). i was hoping that it was not bad 375.00 was more than i wanted to spend.
i think you can get them elsewhere online for about half that. im not suggesting its bad, just a thought.
id find a buddy with AE or an appropriate scanner and see what that code is. sounds liek something that was going out has finally failed and finally telling you about it. |
thought that too. just drove it around for about one hour and to vote. ran like it used too. so i don't know what to do.
bad connection? I was going nuts on my project truck cause it would fire up. but not rev up at all. CEL was on. turned out to be a bad plug on the throttle pedal.
that might be it. is it under the pedal or in the engine compartment?
the pedal it self. there are two plugs on them. i just wiggled the wires going into the plug
thats a thought. could be a random elctrical problem too. im expiriencing one now.
