1997 CCLB 4x4 info needed - Ford Powerstroke Diesel Forum
Old 10-30-2010, 04:50 PM
tab tab is offline
Where can I buy a brake line kit, fuel line kit, and new spring perches that bolt to the frame, and new tanks. Thanks
Old 11-01-2010, 08:22 AM
drives a ranger
Send a message via AIM to kanuck15
brake lines and fuel lines you can make, buying an actual fuel line kit is next to impossible. but just running rubber lines will work. Spring perches i get from Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale and the tanks just do a quick google for them
Old 11-01-2010, 10:29 AM
To Many Projects
I got my tanks of ebay worked great and less then $100 each. There the same as the gas trucks. The fram brackets i got from ford. Also check LMCtruck.com for parts
