clutch safty switch wiring
trying to bypass the clutch safty switch. cant figure ou the wiring. any help would be great. there r 4 wires do witch do i need to tie together.
97 f-250 4x4 zf5 crew cab |
#1) WH/PK is +12V power
#2) DB/OG is output to starter #3) RD/YE is cruise control input +12V #4) TN/LB is output to cruise control so this is basiclly all i need to worry avout correct. so install a push button to jump 1 to 2. 3 and 4 r just responsable for cutting off the cruise when u ingage the clutch and it is on. for now i just jump 1 to 2 so i can drive it and will istall the switch as soon as possible. thanks for the link powerhoghp. |
Ok got the wiring straight. wiring 1-2 will alow the truck to run normal but no cruise. wiring 3-4 alows the cruise to work. if u push the clucth in the cruise still shuts off when the engine revs 200 rpms above where it is set. so it all woks fine. Again thanks for all the help. the reason i had to do this is because i modded the clutch push rod and it would contact the sensor before it was depressed all the way. here is mockup of the mod i did the sleeve on the hiem joint is to long. i cut the one down that i put into my tuck but it was still to short.
