batteries? - Ford Powerstroke Diesel Forum
Old 10-30-2010, 10:51 AM
batteries?
what is the best size and make of batteries for a 95 psd. i'm talking cranking amps.
Old 10-30-2010, 12:54 PM
I installed two new batterys last winter, they are 900CCA each. More than plenty, even in -30°C wheater.
Old 10-30-2010, 01:09 PM
As many CCA as you can find, anything over 850 is fine, but that extra amp can make the difference between starting and being stranded. Also, get an AGM battery, like the DieHard Platinum p2s, 930CCA@0f.
Old 10-30-2010, 01:12 PM
i run interstate megatron plus...850 cca.
Old 10-30-2010, 01:14 PM
i am running Die Hards @ about 850 cca. haven't had a problem yet.
Old 10-30-2010, 02:07 PM
I just put in a pair of Napa's, 880 cca's about $109 each.
Old 10-30-2010, 04:04 PM
autocraft titanium 89.99 group 65-2 1000 ca 850 cca I want to get some odessy's
Old 10-30-2010, 04:13 PM
drives a ranger
Send a message via AIM to kanuck15
if you do my battery mod then CCAs dont make much of a difference, you could have two 500s in there and it will be fine
Old 10-31-2010, 04:21 AM
Two new Motorcraft OEM batteries. My 94 spins blindingly fast and fires in under 2 seconds every time. The more I use OEM stuff on my truck the more I realize it's the only way to go.
Old 10-31-2010, 06:01 AM
kanuk please do tell us of said battery mod.....
