fuel bowl heater plug
ok, thought the plug was on the back side, never 'actually' looked. i see one plugged into itself on the passenger side, is that it? which one? its plugged into itself through some sort of adapter...
thanks |
It should be the one in the center of this photo:
Looks like driver side?
the one on the bottom is the water in fuel sensor and the one above is your heater,this all is run on the ipr line,passenge side is the main plug
I see. So the bottom most of the three?
huh??? most of the three???? im lost...i took my "water in fuel" sensor out.its at the bottom of the fuel bowl...we (me/you/org members) are not idiots when it comes to our diesel,i and a bunch of us know when its time to drain the water from the bowl and change our filters...so we dont need our dummy lights..take it out and reroute the ipr line,leave the heater plugged in...this way when you remove your fuel bowl the basterd line doesnt get in the way of gettin to that line on the bottom of the fuel bowl.just a thought.....i remove mine all the freakin time it seems
Why would you leave the heater plugged in?
Sorry I meant the very bottom wire in the pic. I blew my number 22. Going to unplug and leave it that way. I just don't want to pull the wrong one and blow the fuse again...
I'd thing the most bottom is water in fuel. Since water is that far down. Look in the bowl and see what goes where
i agree. lol duh! should have known, i just read its the second one up on another forum. its dark and getting late and wifey needs trasnportation tomrrow. the batteries need charging too. so im just going to unplug it for now.
thanks for the help guys! hope this is the actual short. too bad it had to go now, bad timing, the bowl is going bye bye in a few weeks... |
