no start - new info
ok, so those of you who have followed my problem, i have new info...
my wife went to start the truck, finally we have visual data. this time the WTS do NOT come on, and she said there is a light that has something to do with engine temperature. without being there to see it thats all i can say. PCM? thoughts? |
sounds like the 22 fuse on the simple side of things. PCM could be the culprit as well. How does all the wiring look? there could be a gremlin in there as well
thought about that too. is the #22 under the dash? and is the #30 fuse deal an SD thing? ive thought about unplugging the fual bowl heater, guess i should finally do that. the wiring ive seen looks fine, but ill take a look at the others.
the 22 is under the hood. its a truck killer for sure. never heard of the 30 fuse thing so must be an SD thing
thats the fuel bowl heater fuse right? seeing 22 and 30 so much i dont want to get the two confused...
that should be labeled MAXI right? there are a ton of those iirc |
yes 22 is the fuel bowl heater circut. It is a maxi fuse
i really really hope its been the fuse the whole time and it finally blew. and that the FBH is the cause.
Its not unheard of or even uncommon. Id unplug the bowl heater and check that fuse
