Eyelet on clutch master cylinder
The eyelet is wore out can you take it off or do you just get a new master
On the diesel stop they talk about a fix on ebay where you cut the eyelet off and put a new one on but I can't find it anywhere
You can replace the piece but it will brake again. I bought the kit on ebay. you cutt off the end of the shaft and bolt on a new piece that makes a permanet fix. I'll try to find it.
Found it on ebay
Type in "Ford Clutch Rod End" This is what i used and it works perfect. It is a pain in the ### to do but well worth it. Fixed for 3 years so far no problems. Good luck. |
How does it connect to the pedal side. pulled off the wore out piece the eyelet goes onto.
DO you cut off the pin and drill a hole
I have it done to my truck and its flawless. You cut off the eyelet end and put it on. Instructions come with it.
It just replaces the eyelet with the bushing with this piece. You cut the end of the shaft off and put this in its place. If you buy it you will understand better.
sure looks a heck of a lot better gonna order it today
Like i said before its not the funnest thing to fix all upside down trying to get in that little spot with a saw. But it is well worth it when its done. The best thing that i found to work with cutting it off is the dremal tool with the flex extension cuttoff bit alot faster than a hacksaw. Good luck with it hope it works out for ya.
