ifs to 60 swap - Ford Powerstroke Diesel Forum
Old 10-22-2010, 02:16 AM
ifs to 60 swap
got my kingpin dana 60. im not positive on the year althought i do know its around 86. got the kingpin rebuild kit, wheel bearings and seals, calipers, pads, and the rotors are getting turned. my rsk will be here next week. i found some superduty springs with 1.5'' lift for like $350. i wanan get those but im curious as to how i mount the rsk bracket? also where can i find a good used track bar and bracket? already checked ebay and junkyards. i was wonderin if the tuff country 4 inch drop would work
Old 10-22-2010, 11:18 AM
The drop bracket I have just uses the factory track bar drop bracket, the best place to find the track bar and bracket would be on ebay. Also you will most likely need a drop bracket with the lift.
Old 10-22-2010, 12:10 PM
Feedback Score: 5 reviews
To install a d60 with SD springs you use a RS kit. With 1.5" SD lift springs you getting close to needing a crossover steering kit and a new longer adj track bar and mounts or you will have bump steer issues. We developed the RS kit SD spring swap and have everything needed and instal help. If we can help please PM.
Cary
Old 10-22-2010, 12:15 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
Dana 60 swap is the best thing you can do
Old 10-22-2010, 02:41 PM
well the kit comes with the drop bracket but i still need the stock bracket and the track bar.
Old 10-22-2010, 03:15 PM
Not necessarily we can get you a longer adj track bar and mounts..welding required.
Old 10-23-2010, 02:18 AM
well i know i need new springs and for $350 i can get the 1.5 lift sd springs. i decided im just buyin the stock track bar bracket and adj track bar from somewhere
Old 10-23-2010, 09:21 AM
coud just kill 2 birds with one stone by buyin the tuff country 4 inch drop bracket and not use the bracket that comes wit the kit? then all i would need is the adj track bar?
Old 10-24-2010, 12:18 PM
???anyone////
