fuel additive
Ive been using PS Diesel Kleen in about every two to three tanks. but with winter time coming up, how often do you guys use additives and what kind of additives do you use? I do know my mileage has dropped a bit since the temps started getting colder.
I put 8 oz. of diesel kleen in every fill up
putting in every fill up, would it hurt anything?
I put additive in every fill up. I get big jugs of howes diesel treat and mix in 4oz of 2cy oil. Then add the mix to my tank like you would any other additive. I get a little better mileage and anti gelling from the howes, and my injectors run a bit smoother thanks to the 2cy oil.
If you are in a 'colder' climate, use the Diesel Kleen in the white bottle every tank. It will keep your fuel from gelling.
thanks for the help and info
does it matter what type of 2 cycle oil?
and can you mix that oil with diesel kleen in the silver bottle? Last edited by MondoSteve; 10-24-2010 at 09:52 AM. Reason: forgot |
I just get the cheap super tech tcw3 stuff from wally world. Some people say 1oz to 1gal of fuel. I just add it to the howes diesel treat and add the reccomended amount of howes mix
i use the white power service in the winter and the silver high performance bottle in the summer. every fill up. it seems to take away a little rattling volume and idles smoother i think. def worth it i broke it down and its like an extra $1 per fill up. def worth it to keep my truck on the road forever
