49 Degrees and already barely starting... - Ford Powerstroke Diesel Forum
post #1 of 20 Old 09-19-2010, 08:23 PM Thread Starter
Well it got down to 49 last night, and today my 7.3 barely fired. After one cycle of the glow plug is cranked slower than a Farmall M. Second cycle and it barely fired. Smoked out the shop! I just put 8 brand new Motorcraft glowplugs in it, and the left bank has new Injector/GP Harnesses. Bad solenoid? My wait to start light comes off pretty quick. i know i'm due for injectors orings but could that really be a cause? Even on a 65 degree day I get a little smoke on the start up. Its not oil, i barely use any and it smells of unburned diesel, I've wedged my face in my exhaust a few times! Any help appreciated!
4th Fastest Stock Motor'd Duramax in the Country, being hauled behind my 7.3 Dually with 300k still going strong!
SeEKandDESTROY2 is offline
post #2 of 20 Old 09-19-2010, 08:35 PM
Shade tree mechanic
95dieselsmoke's Avatar
I'd look into the GPR and see if its functioning properly.
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #3 of 20 Old 09-20-2010, 06:25 AM
ridiculously_necessary's Avatar
you said "cranked slower..." are you talking the starter is barely turning the motor over?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 20 Old 09-20-2010, 08:09 AM
kw900driver's Avatar
Send a message via AIM to kw900driver
I am having the same problem! I think mine is the gpr, get a lot of white smoke!
Mike
'09 F-250 Lariat Crewcab Longbed
6.4 PSD
Spartan tuned
DPF deleted
Industrial Injection twins
EGR to be deleted once I get the blowoff valve installed and lots of other upgrades to come.
Sold:
97 Ford F250 HD Supercab XLT Longbed
AFE Stage 2 Intake
3" dp
Bully Dog exhaust
Hypertech programmer-getting 6 pos chip soon
Hankook all-terrains on Mickey Thompson classic II
Autometer: Pyro, Trans, Boost guages in A-pillar
Beans IDM Mod
Dana 60 swap
kw900driver is offline
post #5 of 20 Old 09-20-2010, 10:16 AM
Guest
Glow plug relay would be the first thing i would look into
xxxxxxxSTROKE_THIS_F-250 is offline
post #6 of 20 Old 09-20-2010, 10:20 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
GPR and batteries are first place to look
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is online now
post #7 of 20 Old 09-21-2010, 12:59 PM
bucwheat's Avatar
I had the same problem ,after putting in a block heater,new batteries and glowplug +relay,I about gave up until someone told me about a gear reduction starter,I checked into it and ordered one through DB Electrical,it only cost $106.95. I installed it which weighs about half the stock starter,I could not believe how fast this thing turns the truck over ,amazing,I get a smile on my face everytime I start her up.Best money I ever spent.This is the site :sales@dbelectrical.com check them out great co. to do business with.
1997 F-350 CC Dually
Power Hungry performance chip. DIY air intake ,4" Diamond Eye exhaust, Trans temp gauge,Pyrometer gauge
10,000 Lb. Warn Winch, 1 million candle power auxilary lights,black heavy diamond plate bumper/brushguard
bucwheat is offline
post #8 of 20 Old 09-21-2010, 03:28 PM
Strong_Racing_43's Avatar
You might need new batteries if it's cranking slow, and replace the gpr.. But still if there is alot of white smoke your injector o-rings more then likely need replaced.
05 6.0...
97 7.3...
stock
Strong_Racing_43 is offline
post #9 of 20 Old 09-21-2010, 04:15 PM
how long does the white smoke last? it could be injector o-rings.
honestly, if its cranking slow and your batteries are good i would lean towards the starter. i too got the gear reduction starter (imo, its 3x as heavy as the stocker) and WOW. i can start 49* no glows. imo weak batts or weak starter. you could try jumping the relay, but that wont make your starter spin faster.
-Matt
DIY 6637
Marinco Mod
post #10 of 20 Old 09-21-2010, 08:23 PM
WidowMaker's Avatar
Do you have a part # or a direct link to the correct starter... I could not find a listing for a 7.3 or a 444
Thanks
WidowMaker is offline
