85 powerstroke conversion
I have conveted my 85 to a 95 powerstroke with the help of a donor truck.The dash, wiring, motor, and tranny all installed in my 85 crew cab. I Would like to leave the 85 axle. Is there some way to change the abs/speed sensor. Maybe a aftermarket or make it run off the tranny? Anything will help.Thanks!
did you use the 85trans? if so you can use a electronic sensor in place of the mechanical
You could mount the exciter ring to the drive shaft.
95 trans E40D. I have found a relocater that moves it to the slip yoke off the tranny, but haven't make contact with the supplyer yet!
Does any one know where I can find an after market exciter ring that will install on the slip yoke of E40D tranny. I found one, but there has to be more than one company making this kind of mod? thanks
Fixed my own problem by welding 32 tooth motorcycle sprocket to my slip yoke and the fabbed a bracket off the tranny to hold the sensor 1/8 inch from sprocket. works great.
