rough idle on start up - Ford Powerstroke Diesel Forum
Old 09-14-2010, 06:21 AM
my 95 psd with 244k on it just started taking twice as long to start, and when it starts, it idles really rough for about 2 seconds then clears up. doesnt have as much power, and smoke is way more gray than usual. any ideas?
Old 09-14-2010, 07:37 AM
loss of compresssion is my first thought. you could have sticky injectors though.
Old 09-14-2010, 02:11 PM
injectors are stage 1's that have around 12k miles on them. what would cause loss of compression?
Old 09-15-2010, 05:57 AM
bad injector o-rings, dusted motor, bent rod, valve issues.
is your fuel pressure good? hpop could be tired. hard to say. check your icp too.
Old 09-15-2010, 09:25 AM
ill pop the filter cap today to check out the fuel filter. what should my fuel pressure be?
Old 09-16-2010, 06:42 AM
check you HPO res befor you start it ( allen plug on tank) if it is more than a 1/4 - 1/2 inch low you probubly have a bad injector oring
Old 09-16-2010, 06:54 AM
godo point. check your oil level too. i know when these psd's get low they can do that. i think it has to do with the LPOP's ability to feed the HPOP and where the pickup tube or something...
