oil pan with ot pulling motor - Ford Powerstroke Diesel Forum
Old 09-13-2010, 02:48 PM
is there a way to do it with out movein the motor
Old 09-13-2010, 07:34 PM
I guess you could cut the supports...easier to just unbolt the motor mounts and lift it up til you can get the pan off. IDK if you can do it on a powerstroke but we've done it on a 70 chevy smallblock motor before. As close as that support is, that motor is going to be WAY up there before you can get the pan off.
Old 09-14-2010, 06:17 AM
i have heard of people unbolting the trans, then motor mounts and jacking the motor up enough to get it out. just be careful.
Old 09-14-2010, 08:30 AM
well i guess i have to pull the motor
Old 09-14-2010, 09:38 AM
I recently pulled my motor to install a new oil pan. i was told it was the only practical way.
Old 09-14-2010, 02:07 PM
Had to put a pan gasket on my 95. Had to pull the trans/t-case because the clutch and flywheel would not clear the bellhousing. Pulled the turbo, downpipe, radiator, fan, fan shroud, a/c compressor, powersteering pump bracket, popped the fuel lines off. unbolted the mounts and had to raise it about a foot with a tractor with a front end loader. its gotta go waaaay up there cause the pan has to come down a ways from the engine to clear the oil pickup tube and the crossmember at the same time. Good luck
Old 09-14-2010, 08:18 PM
Ah ****, I was asking myself the same question. Was hoping I would be able to get it out with out lifting the engine. Don't have to tools for that.
Old 09-15-2010, 05:46 AM
well its an opportunity to clean the block, paint it, rebuild the oil cooler, check for corrosion, easily replace injectors or glows, etc. a list of 'might as well's' while you in there.
Old 09-15-2010, 08:36 AM
ill clean all the junk of the motor but its not getting painted. i only open the hood to work on it. im doing glow plugs but the injectors are way down the road.
