IPR plug? - Ford Powerstroke Diesel Forum
Old 09-11-2010, 03:25 PM
IPR plug?
I'm wondering if the plug for the IPR sensor is supposed to be loose. I think it's the IPR sensor. Its the plug on the HPOP closest to the fuel bowl. The one with the metal clip. I have some troubles with unburnt diesel upon cold starts and I noticed that this plug was quite loose in the HPOP. It doesn't look broken so I'm not sure if it's supposed to be like that.
Old 09-13-2010, 06:42 AM
It should be nice and snug... is it fully plugged in with the wire clip flipped down?
Old 09-13-2010, 06:46 AM
it's the piece attached to the IPR that is loose not the plug itself. If I were to unplug the cord I could wiggle the end the plug goes into.
Old 09-13-2010, 06:48 AM
drives a ranger
Send a message via AIM to kanuck15
should be a brass nut and a sleeve with a flange on it holding it tight on there
Old 09-13-2010, 08:09 AM
x2... sounds like you need to find that tin nut and spacer.
