oil all over - Ford Powerstroke Diesel Forum
Old 09-11-2010, 01:35 PM
oil all over
i went to move my truck today and saw some oil. i went to look to see were it was from and saw that everything was covered in oil. it holds good pressure from what the dash is saying. is there oils lines or something that could be leaking or is the pan gasket broken
Old 09-11-2010, 01:46 PM
What is everything? Motor? Underside? What?
Is it coming out fast or slow when running? At idle or higher RPMs?
If it's more at higher RPMs it's probably a high pressure oil Oring somewhere.
Wash the oil off and see if it returns and where it returns.
Old 09-11-2010, 01:54 PM
its all the oil pan down. its went i drive i think because i cleaned before i left for the dump and when i got back it looked almost like it did before
Old 09-11-2010, 01:58 PM
So it starts where the pan bolts to the block and no higher up?
Old 09-11-2010, 02:07 PM
ya its no higher then the pan its all down low
Old 09-11-2010, 03:45 PM
Not in the valley or anything? Not under the turbo?
If not you might've just lost your pan gasket
Old 09-12-2010, 04:59 AM
on oil under valley its dry. how hard is a pan gasket to change
Old 09-12-2010, 01:03 PM
Not fun. Pretty sure you have to pull the motor. I think I've heard of guys just lifting it up and doing it but I'm not sure if it works.
Old 09-12-2010, 01:32 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
You can lift it but it is so far out at that point you mise well remove it.
