engine change
I have an old 95 f350 powerstroke. It has about 300,000 miles. Its about time to replace the moter. The 95 powerstroke is 210 or 215 horse. Im looking at rebuilding this motor or putting a new motor in (more horses) but still stock. Can I put a 02 7.3 in and what will I have to change.
whats wrong with the 95? 300k isnt near the end!
95 is the 210 hp. and whats wrong with 300,000 she still has life
![]() are you losing compression? hate to see you buy amotor if all you have is tired injectors or hpop. if you do get the 02, put your 95 forged rods in it! you could probably save money by going over your motor. if you have good cylinders (no scoring, etc), you can upgrade your hpop, injectors, turbo an chip for what you might pay for a crate. and get more power. anyway, curious whats wrong with the 300k motor anyway? |
A typical 7.3 rebuild is 5k.
02 motor will work as stated above, but changes will have to make it work. however, you will need to convert to a electric fuel pump since the sd engines do not have the hole on the top of the block for the lift pump. |
Pm sent..........
i see.
hpop - about $600 give or take for new or used (dieselsite has an adrenaline 17* for $600) there have been recent posts on here about a guy somewhere that can rebuild these cheap and good quality... anyone? injectors - $300 to $1500 depending on rebuild, reman, or new or stage 1's (diyinjectors.com if your up to it yourself) turbo - $170 to $300 DIY rebuild. $700ish reman, $1000+ ugraded turbo chip - $300 to 700 (TW, DP, PHP, Beans, ect) glows - $80ish online (motorcraft - no autolites) machine work $1200 estimated, depends on your machinist or your connections headwork - ??? 7.3 rebuild kit - about $900 (pistons, rings, gasket set, injector o-rings, oil cooler seals, etc, etc.) this is all if you assemble yourself. other minor items are left out. sensors, filters, fluids and such. if you rebuild you get to keep your forged rods. if you get the other motor ad want to power up, swap your current rods. Last edited by ridiculously_necessary; 09-08-2010 at 08:14 AM. |
