maaco paint job - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-06-2010, 05:41 PM Thread Starter
jonnydiesel's Avatar
maaco paint job
i got a reg cab truck its green and i want it to stay that way. sadly the paint has screwed up. how are makes jobs on trucks and what do they set up back. i did all the body work i.e. fixed rust spots fixed dents and primed so spots
jonnydiesel is offline
post #2 of 16 Old 09-08-2010, 01:37 PM Thread Starter
no ones used maaco
post #3 of 16 Old 09-08-2010, 02:43 PM
Chop's Avatar
I have known some body guys who do all the body work and disassemble ie; door handles, mouldings on so on and make a deal with the local Maaco and get a good paint job.It's all in what you expect from these franchises,they are all not the same.You can get a base coat, clear coat[two stage] for around 500 bucks,exterior only.You do all the preperation and disassembly.The preping and masking is usually the weak spot on all paint work,and of course the quality of the finishes YOU choose should be considered
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #4 of 16 Old 09-08-2010, 05:14 PM Thread Starter
i started talking to my buddy about it and he told me he knows the owner of a maaco so he could maybe have the trucks importance pushed so i get a better job
post #5 of 16 Old 09-08-2010, 05:23 PM
2006smokin'6.0's Avatar
As Chop said, Ive had good luck with them if you do all the prep work. We pulled all the door handles, lights everything. Then gave it a good blocking. They are more likely to do a better paint job if they have less to mask off. Then we trailered it there. I think it came out great for what it was.
2006 F-350 EC SB 4X4 Lariat
S&B Intake
SCT Livewire w/tunes by IDP/BTS
ARP Studs
EGR Delete
4" Stainless MBRP Dual 5" Tips No Cat
FASS Titanium
ZooDad
CCV Mod
High Idle
3" Leveling Kit
B&W Gooseneck
Custom Whelen Lighting
~Dodge is just a shipping crate for Cummins~
2006smokin'6.0 is offline
post #6 of 16 Old 09-08-2010, 05:30 PM
no-tel-in's Avatar
All I have ever heard about maaco is bad. Though I have never dealt with them
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #7 of 16 Old 09-08-2010, 05:35 PM Thread Starter
im starting the prep work tonight should go easy only two dents and one tiny spot of rust. but i should strip the truck down
post #8 of 16 Old 09-08-2010, 07:24 PM
Location: Casar n.c. A little town of about 600 people i think.
i work for a restoration shop...let me just say this, if they do it for 500 then their gonna make at least half that in labor. that being said...250 for paint is on the lower end of quality materials. We use a clear coat that is expected to be durable for 2 yrs on average (no pealing,cracking or fading) on the car lot cars that we do. (they want it cheap as possible) That clear is almost 100 a gallon including hardner. Most economy base coats are 120 to 150 a gallon. I guess i'm trying to say...just be aware that they use economy products that are not gonna last as long as most people expect them to. Also, as far as i know (unless they have changed) they do not give any kind of waranty. On the other hand if your like me and use the tk then your not looking for show room quality.
Baptist preacher man
'94 f-250, fpr shimmed, diy intake, gutted exhaust, 3" down pipe,
96' ecm upgrade
superchips
future mods...
homemade supension lift
injectors
gauges
paint job
how could any self-respecting person drive anything other than a Ford,preferably a diesel.
Trying to get my wife to sell the Durango, hopefully an Excursion in my future.
jeremy hull is offline
post #9 of 16 Old 09-08-2010, 10:29 PM
Guest
from the people i know, it looks good for about 2 years then it will go down hill quick.
xxxxxxxSTROKE_THIS_F-250 is offline
post #10 of 16 Old 09-08-2010, 11:05 PM
Shade tree mechanic
95dieselsmoke's Avatar
I think its all in the employee doing the task at the time. I have seen complete hack jobs from maaco(which is the usual) and I have seen one certain maaco shop that has a damn good painter on hand that turns out great products. But again, you have to question the paint/clear coat quality that is used by maaco.
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
