OBS HID and Clear Lens Install - Ford Powerstroke Diesel Forum
Old 08-31-2010, 06:39 AM
Finally got around to doing this today, I'm going to try and make this post as detailed as possible to maybe help someone out in the future.
Parts used:
Clear headlights and corner markers from Ebay seller parasitesingle
Clear turn signals bought off of another forum
DDM Tuning 55w 5000K Raptor HID kit
Zip ties as needed
One ring terminal
Here's how it looked when I started:
Its funny how the orange lenses and diffuser headlights don't seem so bad until you've seen the rig with the good stuff installed!
Pull the grille and headlight surrounds. The headlight surrounds can be a real PITA because you've got to snake your arm around between the radiator support and batteries to get the 2 11mm nuts off of the turn signal lenses before the surrounds come out... not fun. Next pull the header panel out. This step isn't completely necessary, but makes getting the headlight housings out way easier. There are 11 8mm bolts holding the header panel in. You end up with this:
Remove the headlight housings from the header panel. I use a pick to help remove those dang clips... once you see one and fight with it for a while you'll figure out a good method that works for you.
Now you get to figure out how to run the wiring for the HID harness. The kit I bought is a high/low kit and has this little electrical gizmo box:
I mounted it on the passenger side of the header panel with a self tapping screw:
The HID harness comes with a connector to tie into one of the factory headlight sockets. The kit didn't come with instructions but a quick phone call to DDM got me the info I needed to get the wires in the right spots. Blue (high beam) to the left, brown (ground) in the center, and white (low beam) to the right:
The wiring going to the driver's side headlight I ran along the factory wiring harness and zip-tied it in place.
Now, time to figure out where to put the dang ballasts:
There are two ballasts (one per side obviously) and the DDM kit doesn't come with any kind of a mount for them, so I bought some 24 gauge sheet metal at Home Depot and used my superior sheet metal fab skills to make myself a couple mounts:
So... where to put the dang things? I was having a hard time finding a good place for them that the wiring harness could reach. As luck would have it though, the OBS header panel has a spot in it that makes a perfect place to mount the ballasts. DDM said not to put them behind the grill, so I mounted them on the back side of the header panel using a couple rivets to hold them in place:
Ballast mounted, this is the rear side of the header panel
Front of header panel showing rivets holding the ballasts in place. Unseen with everything reinstalled on the truck.
Rear side of header panel with both ballasts mounted
Front side of header panel
I didn't have to trim anything off the header panel to run the wiring, there was enough clearance already which was nice. There is one connection on the ballast that will be kind of a pain to get to, but I think by pulling the grille I can get to it without much trouble. I couldn't come up with another good place to mount the ballasts and have the wiring tucked away like I wanted.
Which reminds me... the new harness comes with a fused lead that goes to a +12v source. I ran mine to the always hot side of the starter solenoid on the passenger side fender (no pic of this... pretty self explanatory). There is also a ground for each plug that goes to the ballast that I put behind a header panel bolt. Zip tie wires down you suit your fancy.
Install the headlights back onto the header panel. I reused the stock mount screws on my new headlights because the lower ones that came with the new lights were super cheesy, and my anal retentiveness wouldn't let me just replace the lower ones so I swapped them all. Be careful when doing this so you don't break anything. Reinstall the header panel. Connect all the connections for the new headlights- easy access through the hole in the header panel/rad support. Install new clear corners and turn signals into headlight surrounds and reinstall.
Reinstall the grille. Sit back and marvel at how much better your truck looks now!
Night shots will be posted later. I spent way more time on this job than I needed making sure everything was right and trying to make the install as clean as possible.
A few notes:
The HID lights come with a base that you unsnap from the bulb, install in the housing and install the lock ring, then you have to install the bulb and twist it to lock it in. I had to use a screwdriver to turn the bulb and get it to lock in.
I went with the DDM kit based on the price. Hindsight being what it is, if I had to do it over again I'd have gone with a Retro Solutions kit because they are more complete and come with good instructions. Cost is about double what my kit ran but would have saved a lot of time.
The lights are slow to turn on, which kind of bums me out. I was thinking they'd be quicker but I've heard its common with HID's to have a start-up delay.
I replaced all the bulbs in the corner markers and turn signals with LED's. The bulbs are clear but light up orange... super slick.
The headlight housings I bought are close to, but not quite, a factory fit. There are some small gaps between the light and the chrome surround that weren't there with the stockers.
All in all I'm really happy with how it turned out. Any questions/comments give me a shout.
Old 08-31-2010, 06:40 AM
Tried again, this set turned out half decent.
Crappy wide angle shot
Close up of turns/corners
Can you see the truck? ;D
This was with no flash...
I wish I had gone with clear bulbs for the corner markers because the HID's just wash the orange out and you can't see it anyways. And I'm pissed that even though they are the same brand the small bulb and big bulb in the turn signals are different colors so I'll probably end up changing them all out at some point.
Old 06-01-2011, 10:07 AM
awesome write up! what is the bulb type for the obs trucks? i'm about to order a set of HIDs myself and need to figure out what bulb i need.
Old 06-01-2011, 03:24 PM
looks great gonna do this later on
Old 06-01-2011, 03:30 PM
Stock headlight bulbs are 9007's.
Old 06-01-2011, 03:43 PM
thanks bud!
Old 06-01-2011, 06:09 PM
9004's work as well but the hi and low beam are backwards, good write up, arent you glad you did your corners yesterday on the other one, helped alot getting those out, and if you go with a higher bulb the wash out of orange is less severe, like im using 6k, and my brother has 8k, but the higher you go the more purple it gets, goes blue first though
Old 06-01-2011, 06:44 PM
yeah, i had 5k in my 6.4 and thats what i'm getting again.
Old 06-01-2011, 06:54 PM
Send a message via AIM to lsmith33
looks great...imo only white trucks can pull off clear corners
