E4od fluid question. - Ford Powerstroke Diesel Forum
Old 08-28-2010, 06:02 AM
How much transmission fluid does the e4od take if you just drop the pan and the filter?
Old 08-28-2010, 07:38 AM
Anyone??? I need to change the fluid and i have no clue how much it needs!
Old 08-28-2010, 10:11 AM
I believe it's around 7.5 quarts to change what is in the pan and filter but, your local auto parts store should have that info in their computers. If you still have your owners manual or a service book like Chiltons, etc, the info should be listed there as well.
Old 08-28-2010, 11:40 AM
I found out. Its 8 quarts. Thanks for the help anyways!!!
Old 08-28-2010, 01:03 PM
Yeah, mine took about 7.5 Quarts after a filter change...she shifts so smooth now!
Old 08-28-2010, 03:56 PM
It is about 15 qts with torque convertor drained,Do you plan to change all the fluid?2wd versus 4wd,4wd holds more,larger pan and different filter
Old 08-28-2010, 05:40 PM
just the pan and filter. Its 4wd
Old 08-28-2010, 07:31 PM
Why would you only do a job 1/2 way take the bellhouseing cover off and use a big screwdrive and turn the flywheel and get the drain on the bottom this is just another 4-5 quarts do it right
2 stroker
Old 08-29-2010, 09:23 AM
2 stroker
Well i'm limitted on cash right now and it needed to be done. Doesn't the fluid in the pan eventually mix with whats in the TC? Next time i do it i will do the TC as well.
