fuel pressure? - Ford Powerstroke Diesel Forum
Old 08-27-2010, 03:52 AM
fuel pressure?
Whats the fuel pressure between the tank and the pump? The steel lines where the stainless braided section attach under the powersteering pump are rotting out. Already did a repair on the return side but now its starting to seep on the inlet side.
Old 08-27-2010, 06:02 AM
its actually under vac. there is no pressure until after the pump. that is assuming you have the stock mech. pump.
Old 08-27-2010, 06:15 AM
That's what I thought. Just thought i'd check. Fuel system is stock.
