broke extension housing ZF5
i had a wierd vibration issue pop up a couple days agao it would shake like i was goin over rumble strips from 55-60 mph.
well i looked under the truck today after it magically went away and theres a 3/4" gap where the extension housing broke just after the trans mount on the crossmember all the way around. the transfercase is just resting on the skidplate right now. also, 3 of the 4 bolts holding the rear driveshaft on the flange to the T-case were finger tight.... wat caused this? bad u joint? loose driveshaft mounting? bangin gears broke it? |
My brother's broke when he was in snow ram rodding around and getting a lot of wheel hop. Any photos...his broke right where the trans mounts on the cross member.
thats exactly where mine busted. i got one being shipped right now. $317
i think it was my rear driveshaft came loose because when i went under the truck to see and i think thats what caused the bad vibration |
