For future reference, the same injector o-ring kits are half the price at an international dealer.
Overall, you will need to crank the engine 5-10 minutes to get the air out of the fuel and oil rails in the head. Crank it 20-30 seconds, wait a few minutes, repeat. Glow plugs should have a resistance of about 2 ohms or less. |
I did have it running for a while but not long have not installed the radiator yet. But air is definitely a possibility can't crack no lines on this one I will through the rad in it and run it this is my first power stroke and thinking about it their is a lot of room in that head for air. Thanks
Once it's all together and you have no leaks, drive around until it's at normal temperature, then take it for a good highway/freeway rip. That'll purge any remaining trapped air.
I will give that a shot thanks.
x2, a LOT of cranking. and most report that 50 to 60 miles does the trick for gettin air out of the HPO system.
Thanks will do got to get my trans straight first believe my forward clutch assembly is shot again thanks for the feedback
Mine took about two weeks of driving before it went back to its normal crank time after I replaced the head. Now on a warm day it starts as soon as you turn the key.
10-4 on that haven't really had time to get back to it yet ordered a radiator for it and found out that my 95 has a 94 radiator in it so once I get that I should be able to put some time on it. Thanks for the input.
