Heater control dial restriction - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-23-2010, 09:33 AM Thread Starter
hheynow's Avatar
The heat control dial moves freely from the very cold to warm settings but if I try to turn the dial to the hottest setting I feel a restriction in the dial. I think a pen may have fallen through a long duct by the windshield above the glove box causing a cable restriction.
I removed the glove box but can't see anything. How do I fix this dial restriction?
1997 F-350 7.3L PSD - 326K miles - 40+K on VO - Plant Drive Kit
1984 Mercedes 300D NA - 160K miles - 10+K on VO - Custom Two Tank
Running on VO and biodiesel since May 2006
Without oil you're nowhere!
hheynow is offline
post #2 of 3 Old 08-25-2010, 07:48 AM Thread Starter
hheynow's Avatar
Just need to locate the temperature blend door cable.
hheynow is offline
post #3 of 3 Old 08-25-2010, 08:21 AM
Transmission or Injectors
lwillson's Avatar
The cables run from the heater control to the blend door. Mine is kind of tight when I get to the hot side of center, but I couldn't see anything wrong with the cables when I had the dash apart.
The knob turns a gear which pushes/pulls on two cables that run to the blend door. If you pull the heater control screws out and pull it forward, you can see the back where the gear is. If you open the glove box, push in the tabs on the side, get the box to come out farther, then pull on the whole box, and it will come off its hinges. The cable should mount in the top right area behind the glove box,
lwillson is offline
