Leaking lift pump, Electric or Mechanical?
Hey guys my lift pump on my 96 stroke is leaking in the valley. I replaced the o rings on the banjo bolt set up and its still leaking? I put one washer on the banjo bolt itself and the other in between the brass fitting with the brass fuel lines on it. Is this right? I might have to get a dentist mirror to see where exactly the mirror is leaking. If the pump is bad I need input on what type of electric pump to get?
Thanks! |
Get a stock super duty pump they are really good. I just sold one for 70 that is the going rate for em just look around.
ok coo! Is that the best option? Do you need anything to make it work? or does everything bolt up?
