transmission temp gauge
anyone know of an alternate method of hooking up a trans temp gauge? i dont really wanna drill into the pan sounds a little risky for an amateur like me...
Does anyone know if our E4OD's have the port for this or was that introduced in the 4R100?
If yours is the same as my 99 tranny, there will be a drain plug right above the tranny linkage on the drivers side. Unscrew that plug and the temp probe will screw right in its place. You will probably only lose a drop or two of fluid. Hope this helps.
yeah ^ thats the one im thinkin of. Check for that port. if its not there, the i would assume splice into the fluid line that goes out to the cooler.
how would i go about splicing into the line?
No need to drill the pan just remove the plug as stated above. Its a pressure port same size as the sender.
where is this plug located though? i cant seem to find it...
drivers side of the transmission. Right by the shift linkage.
so u have to take the plug out or what? pictures would be nice if anyone had some
and also what would be the best way to remove this plug?
