Quality ? about some spindle seals I bought
I bought some spindle seals from an online vendor, they are dana/spicer brand and I noticed the oem inner seal is has a metal frame with a spring inside the rubber, and the outer seal also has some metal (maybe a spring?) in it, my new seals are all rubber and I was wondering if anyone is using those kind and has had any problems? And real quick, do you drive the spindle bearing in untill it stops? I did but I'm not sure the OEM ones were pressed in that far. I will have to get a puller to get it back out if it needs to come out. I just drove the old ones out with a punch but I can't do that with the new ones. Thanks!
