newer psd fuel setup on obs? - Ford Powerstroke Diesel Forum
Old 08-14-2010, 09:08 PM
just read an ebay ad saying that the guy put the fuel system out of a 00 psd in his 96. anyone heard of this?
Old 08-14-2010, 09:19 PM
yes, but i would build your own fuel system with electric pump.
Old 08-26-2010, 04:45 AM
Send a message via Yahoo to williamc51
What all would I need to build my own fuel system with an eletric pump
Old 08-26-2010, 05:24 AM
pump, wiring, freeze plug, and either an SD fuel bowl, modded OBS fuel bowl, or fuel bowl delete. i vote for the delete. if you do the delete, youll need a new filter mount and spin on filter (easier than the bowl anyway) if you get an SD pump youll need an FPR. if you get an Airdog, FASS or the upcoming wvodesigns pump thats internallly regulated and you wont need an FPR. you also need to decide whether or not you want a regulated return.
im about to do this myself.
Old 08-26-2010, 06:05 AM
What needs to be modded on the OBS bowl? I'll likely do a fuel bowl delete when I do electric fuel but I haven't heard of any mods needed if you want to keep the stocker.
Old 08-26-2010, 06:20 AM
the factory fuel bowl in an OBS has fuel pulled through it. it wont hold the 70ish psi that and SD bowl does. so you either have to mod the bowl to resemble the SD bowl or get an SD bowl. IMHO, ditch the bowl. unless your way up north and need that FBH. i suppose you can use an electric wrap on a spin on though...
suppose i could be wrong here. i know with a veg conversion for my OBS i have mod the bowl for the electric setup. i will ditch it instead.
Old 08-26-2010, 06:53 AM
Thats right... thanks for the brain duster
Old 08-26-2010, 07:32 AM
np, we all need one now and then.
Old 08-27-2010, 12:28 PM
Electrical Ogre
I did a fuel system with 6.0 parts, so anything is possible
Old 08-28-2010, 07:31 AM
SD Fp, areomotive reg filter heads, relay diesel rateed HP Hi temp hose, fittings if you not in a hurry you can get the pumps on e-bay i picked up two new ones for 100.00 each
