coolant temp - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-13-2010, 01:48 PM Thread Starter
coolant temp
where should my coolant temp gauge run at? i etheir have a bad gauge or a bad thermostat, first diesel don't know for shure. gauge will jump up when it moves, and it stops just before the n in normal, is this right?
95 f250 is offline
post #2 of 10 Old 08-13-2010, 01:58 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
On my 7.3 (it's an 01) it's usually between the "o" and the "r"
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #3 of 10 Old 08-13-2010, 07:38 PM
ive just bought a 94 and my gauge was acting up like that and i had to put a manual on mine, I would just go ahead and do it so it wont bother you anymore,, I had my dash thermsotat just laying to the side out there and my gauge still flutters, so i know it was the gauge now, manual you will know for sure
bohawg is offline
post #4 of 10 Old 08-15-2010, 10:06 AM Thread Starter
i realized it was my thermostat like twenty min. after i posted this. what is the best place to drain the entire system from, what additive should i use?
95 f250 is offline
post #5 of 10 Old 08-15-2010, 10:16 AM
POWERSMOKIN's Avatar
There's a pet**** on the bottom left of the radiator. Use caterpillar coolannt. Or mkotorcrraft diesel additive to reduce cavitation
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #6 of 10 Old 08-15-2010, 06:31 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 121 Post(s)
to totally drain the system, open the valve on the radiator and let it drain, disconnect a heater hose and blow air through it to clear the heater core. Lastly, there is a block drain on each side of the block above the oil pan.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #7 of 10 Old 08-16-2010, 09:33 AM Thread Starter
will the block not drain threw the radiator? i'm not worried about a coulple of quarts. where would i by the cat additive at? thanks for the advice
95 f250 is offline
post #8 of 10 Old 08-16-2010, 12:19 PM
rolsmojave3's Avatar
You might as well get all of the s!hit you can get out of it while you have it drained...I'm sure you'll have some stuff in there.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #9 of 10 Old 08-17-2010, 04:40 AM Thread Starter
what will these block drains look like, and will i need to drain both sides?
95 f250 is offline
post #10 of 10 Old 08-18-2010, 12:50 AM
if it were me, id drain it outta the valve on the bottom of the radiator, refill it with water, and run it for like 10 minutes, drain it again, fill with CATERPILLAR coolant, or prestone coolant and use the motorcraft diesel additive. if you use CAT, you dont need the additive
~Mike Lewis
265,000MI
