engine shuts off - Ford Powerstroke Diesel Forum
Old 08-11-2010, 07:06 PM
engine shuts off
hi i posted this in another forum with no response, so ill try here. when i close the hood too hard the engine shuts off, today at the grocery the bagboy slammed the rear door and the engine skipped a beat but kept running. i did tug & pull in the engine bay.anyone know where i need to go next, any help is appreciated, thanks
Old 08-11-2010, 07:16 PM
my first thought was you have a loose connection w/ the cam sensor.........
Old 08-11-2010, 08:02 PM
i ll check it out after work ,thanks
Old 08-12-2010, 05:52 AM
check the fuse box as well. may be a bad/corroded ground somewhere as well.
Old 08-12-2010, 04:26 PM
i checked cps and tugged on wires under dash, could not get a response from engine until i shut drivers door engine missed a few times than cleared up,did this twice more than could not get it to happen again. (so far) neighbors starting to wonder why nutcase keeps slamming doors could my idm have an internal short and is it grounded though the body or through wiring? iam i on the right track or should i go back to looking for a bad ground, i have not seen anything else effected by this,lights,gauges or radio
