Upgrades for 1995 F350 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-14-2010, 11:02 PM Thread Starter
I have purchased a 1995 F350 Crew Cab Long Bed (7.3L of course) and I am making the following upgrades:
1) Added a Edge Evolution CTS chip / gauge unit
2) Straight pipped the exhast.(already had a 4 inch down pipe on the manifold)
3) Added Ford AirDog II DF-130/75 with built in adjustable regulator from 45-75 psi, 130 gph
4) Installed a S&B AIR FILTER KIT
5) Completely by passed the ERG system
What else would someone recommend that I could do to improve the performance of my truck?
palikero is offline
post #2 of 13 Old 07-15-2010, 06:21 AM
superduty4x4's Avatar
Not sure how the new Edge CTS is, but the old stuff doesn't have a real good reputation. A custom burned chip (Total Diesel Performance, aka TW, DP Tuner, Bean's, Swamps, etc) will make more/better power than the Edge tuners of old. Aside from that, look into HPOP and injector upgrades for more power. If you go real big on the injectors then you'll need fuel system mods and a bigger turbo to keep up.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 13 Old 07-15-2010, 03:11 PM
StrokerIH's Avatar
Quoted: 4 Post(s)
whats a ERG system?
97 F250 HD, XLT, ext. cab. long bed, 7.3 4X4, E40D, 3:55LS, 3" DP, 4" MBRP, 6" tip, No Cat, No Muffler, E-Fuel, TS 6 pos chip, Front add-a-leaf, 6637, Marinco mod, 265/75r16 a/t, Door keypad, Meyer 7.5' Poly Plow
03 Excursion 6.0, 4x4, 3:73, No Cat, No Muffler, Blue Spring, Coolant Filter, Zoodad mod, SCT X4, 24" wipers
StrokerIH is offline
post #4 of 13 Old 07-15-2010, 04:00 PM
FENKER's Avatar
1. the cts can be custom tuned for u and if u dont it will be pretty much pointless for the fuel syatem, php will do it. powerhungryperformance.com. if not get a normal custom chip like stated above.
2.they dont make a 4" down pipe and its pretty muck impossible to get one to fit.
3.the fuel should be last but if u have the money go for it. but the fuel with stock injectors wont do anything.
4.good
5. i dont think we really have a EGR
what u want to do is intake, exhaust, gauges, chip, hpop,(17*, modded 17*, or adrenaline) injectors(stage 2 or 3 if u have the fuel system, i think if u got stage ones the fuel again wouldnt really be worth it, would be cause u will have electric fuel instead of mechanical. turbo.......anything bigger than stage ones the turbo wont keep up, the d66 will work pretty good for mild power with stage 2s i have heard, but a H2e or modded H2e would be best......its alot of money to get alot of power out of these. and with just a cts u wont get to far at all......
hopefully mattp still goes on this forum, he knows alot about pumping these obs's up
1997 f250 HD ex cab sb with southbend 450hp singlemass clutch, 6" lift with 35"s, 3 1/2"down pipe with straight pipe, afe stage 2 intake, tw chip, ccv mod, 17* hpop, 120v idm,vegistroke system V3. (AKA electric fuel for diesel and veg side)
UPCOMMING MODS:diy fuel bowl delete,fass pump for diesel side, stage 2's, d66 turbo or modded h2e
no parking cone at stanford university
FENKER
FENKER is offline
post #5 of 13 Old 07-15-2010, 04:01 PM
FENKER's Avatar
oh ya and if u have an auto u will need alot of work done to it for all the power, even with just a chip the stock tranny will go out. if u have a manual, a single mass flywheel and clutch is best
FENKER
FENKER is offline
post #6 of 13 Old 07-15-2010, 04:04 PM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
havent read thru but i wud get some gauges,oil,tranny,pyro.boost is really fer fun,not unless urr pushin 200 psi of boost.
harley1rocker is offline
post #7 of 13 Old 07-15-2010, 04:12 PM
shaking things up
jethro's Avatar
i know alot as well get a custom six position chip get a full compliment of gauges boost, egt-install this in the driver side manifold right as it turns up as that is the #8 cyl and know to run the hottest you have a 3in down pipe not a 4in you have to beat a 3inch in cant imagine a 4" i have an airdog system this is a big mod you better get some other stuff first before you put your money into it wont really help you stock gotta mod it more, s&b good choice i run their filter, and we do not have an egr we have a ccv and you can mod it i just vented mine to atmosphere it will smoke alot after i get the oil hot and push 40psi of boost
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #8 of 13 Old 07-15-2010, 04:47 PM
StrokerIH's Avatar
Quoted: 4 Post(s)
assuming that he ment EGR. then yes fenker you are correct obs's do not have them. i beleive they were not until the 6.0 but not possitive on that.
post #9 of 13 Old 07-16-2010, 10:48 AM
TANPOWERSMOKER's Avatar
Dose the modded ccv really do anything other than no more mess/oil in the intake tube?????
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
post #10 of 13 Old 07-16-2010, 11:52 AM
StrokerIH's Avatar
Quoted: 4 Post(s)
i beleive the ccv mod is to just eliminate the oily mess in the intake tube.
