f-350 blocks - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-21-2007, 04:04 PM Thread Starter
materi's Avatar
f-350 blocks
I have a 96 psd and want to give it a little lift nothing to crazy just enough for 35's (315). i was thinking 350 blocks out rear and an add a leaf in front. my question is where do i get 350 blocks? dealer,junk-yard.
thanks
materi is offline
post #2 of 21 Old 05-21-2007, 04:10 PM
7.3 tech, supporter
fordnut85's Avatar
Your truck should have a factory 2" block already and I am strongly against "stacking" blocks for more lift, they have a bad tendency of spiting out when the suspension cycles and I don't have to say how dangerous that is!! You would be better off going with an add a leaf in the rear also.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 21 Old 05-21-2007, 04:12 PM
0560kranch's Avatar
you can get brand new blocks and u-bolts from ford if you'd like, if not just buy 4 inch blocks from any online store, I have a 250, and my buddy has a 350, he wanted his lower and I wanted mine higher so I took his 4" and he took my 2" blocks n u-bolts.
2005 F-250 6.0 CC/SB KING RANCH 4X4, AIRRAID INTAKE, ZOODAD MOD, 4" STAINLESS MBRP EXHAUST 5" TIP, 35x12.50 R 18 MUD GRAPPLERS ON STOCK KR RIMS ( NEW 35x22'S COMIN SOON), SCT XCAL2 FROM DJ'S, LEVEL KIT W/ F-350 BLOCKS IN BACK
0560kranch is offline
post #4 of 21 Old 05-21-2007, 04:47 PM
Farmy22's Avatar
Stack blocks=not cool. I knew this and still did it for a while till i spit a block out on the highway. It seemed like a cheap temporary fix to fit my 39.5s. For almost the price of blocks and U-bolts you can do it stronger and safer by either buying a shackle flip kit or if you have the resources, make one. Its a little work but its worth it imo. Just a suggestion. Of course the best way to lift is with springs. I just used the measurements from my truck and pictures from this site to make mine. There are some other interesting things on this site too.
Ford/Dodge
Noisy, knockin, fartin, smokin, chuggin, nasty, dirty, stinky, blown, turboed, natural aspirated, fuel waxin, oil leakin, torque makin love of my life Diesels.
96' F-350, Snorkel, Programmer, Big Injectors, hood stack, 10" lift, Locked and spooled Rockwells, 53" V-treads.
I also have an quad cab cummins, 6 speed, air raid, fass, 4 inch straight pipe, & Smarty tuner.
I like places so cold you can spread diesel fuel on your toast like apple jelly.
Farmy22 is offline
post #5 of 21 Old 05-21-2007, 05:51 PM Thread Starter
materi's Avatar
i know about the rsk out there but i could not imagine the cost of shipping up here to canada. i don't want to stack blocks i thought the 350 just had taller ones and i would just replace them. if i put more springs in the rear would it be a rougher ride? What are the dimensions on the factory blocks?
materi is offline
post #6 of 21 Old 05-24-2007, 05:14 PM
0560kranch's Avatar
f-350 blocks are 4 inches, f-250 blocks are 2 inches, just swamp the blocks, you do not have to stack anything
post #7 of 21 Old 05-26-2007, 04:11 PM Thread Starter
materi's Avatar
i did some searching and am wondering i know with just a leveling kit on a 350 you can fit 315/70/16, how about a 250 with 4"blocks in the rear and an add-a-leaf in the front?
thanks
materi is offline
post #8 of 21 Old 05-29-2007, 08:40 AM
Ramsmoker's Avatar
Cool Blocks
What I have done is go to our local tire a wheel store and talk to the shop guys. When they do lifts, they throw the old blocks and U-bolts in a scrap bin out side. They give them to me. Hey, go make a new friend. I have stacked blocks and have only had wheel hop problems. If you do, weld the blocks together then carefully torque and retorque the U-bolts.
The Ex -box. Total RSD system. See what happens when you let attorneys run your Country!!!! There's nothing wrong with a Democratic society, we just need to get rid of Democrats. 2001 Excursion. 2003 Cobra Terminator all pumped up. Now this is fuuuuuun.
Ramsmoker is offline
post #9 of 21 Old 07-11-2007, 06:05 PM
My 95 F250 fits 35's with a Leveling kit in the front and no lift in the back.
1995 F250 Auto w/ Built E4OD w/ all the upgrades, HD Billet Multi Clutch Torque Converter, DIY Tymar intake, Dfuser 18k, SCT, A pillar guage pod w/ Pyro, trans, boost, 3-3.5" downpipe, 4-5" straight pipe to 5" Mitre Stacks.
Drrm80 is offline
post #10 of 21 Old 07-16-2007, 08:38 PM Thread Starter
materi's Avatar
what is the measurment from the groung to the top of the wheel opening. i actually just put three extra springs in the back and one in the front and am still thinking about 35's
1996 F-250 xl 380,000km 4:10 posi 5 speed , 3"dp 5" stacks, diy tymar intake, D.I.Y stg1 injectors, T.W* 6 pos chip (stock,emmisions,economy,tow,exteme,hi-idle) dual gauge pillar (EGT,boost) pro-comp 16x10 series 1069, m/t baja atz 305/70/16, 1 add-a-leaf front and 3 in rear w/ 4" blocks, Valair -06 smf clutch conversion
My RIG makes me money everyday
materi is offline
