testing Injectors? - Ford Powerstroke Diesel Forum
Old 04-15-2006, 10:14 AM
testing Injectors?
How do you test the fuel injectors to see if you have one not working?
Mark
Old 04-15-2006, 11:04 AM
from what i know, the easiest way is to do a scan to check for codes, i beleive that if one is bad it will show, and location of bad one.
there are also companys that can do a more precise measurment, once out of the truck
Old 04-15-2006, 11:17 AM
I thought so, being that they are under the valve cover. My motor starts rough (RA RA RA RA RA) then (RARARARA) purrs like a kitten but kind of misses slightly, Its a 95' Is that normal its been doing this since I bought it,every time I start it.
Old 04-15-2006, 01:24 PM
sounds like the injectors need to be re o-ringed.....common on the older ones. there is an updated o ring style also.........Marc
Old 04-16-2006, 04:28 AM
Were can I get them? from Ford,do they sell them as a set? and do they leek oil arround them is that why they go bad?
Old 04-16-2006, 06:07 AM
as far as i know they are a dealer only item.....but they may be available aftermarket. the kit will comsist of three round o rings, one flat o ring, a steel ring, and a copper crush washer for each injecotor. you will need 8 kits. there is also a possibility that you may have an injector missing cold which means putting o rings on them should help your starting issue but you may still have the cold miss.......
this all said, diagnosing injector o rings is kind of an experienced hunch thing. you should make sure to thouroghly test your glow plug system before deciding to pull the injectors, and make sure to follow a good instruction manual if you are going to pull injectors as one little step out of order can mean hydrolocking a motor..........Marc
Old 04-16-2006, 06:42 AM
lukecline
Guest
Posts: n/a
i believe you can also get inj o rings at international. The o rings that fit the t444e are the same thing.
Old 04-16-2006, 03:46 PM
injectors
get an auto enguinity scan tool an check all of your injection pressures and you could possibly need ipr re-o ringed
Old 05-10-2006, 08:16 AM
Question Life expectancy of injectors?
Anyone know the life expectancy of 7.3L (original Ford) injectors?
Old 05-10-2006, 01:04 PM
Mine lasted 335,000 miles. Thought it was time to have rebuilt.
