alright im getting pissed
what all can cause a rough idle and a very inconsistent sounding engine at higher RPM's and absolutely terrible fuel mileage...the truck has a ton of power but just sounds like azz and darn near shakes me to death. im out of ideas and so i need a list of things that can cause this...im just trying to pick others' brains cause mine is done picked! Im about to pull the motor and rebuild the whole darn thing. and im actually starting to think that its not really the engine at all, im starting to think it might be TC related, unless im consistently getting air in the HPOP system but when i pull the plugs the oil has no bubbles in it and the oil level is right there at the top. I don't know if its an IDM or ECM issue or what but its driving me crazy because ive pretty much ripped the engine apart trying to find this...who knows it might just be that i need all new injectors. So yeah if yall can just list all the things you think might cause these issues it will give me some new ideas. OH yeah NO CODES!
VC harnesses checked out OK? Have you checked/cleaned your IPR? HMMM....stg2 or 3 injectors would probably cure everything.....
well those are about the two things i haven't checked...see thats why i posted this, gives me ideas...although injector buzz was good so that somewhat eliminates the VC harness although i have seen bad harnesses but good buzz tests. the IPR ive been reluctant to pull apart although i did inspect the wiring when i had the fuel bowl out....well im gonna have 3 days off after tuesday so i may just do that then...oh and i found a pump that still runs the low sulfur fuel not the ULSD so im trying to run a tank or two of that through it to eliminate the fuel type. Im gonna pull the VCs and make sure everything is still bolted down...we had a truck roll in the shop that one of the exhaust rocker arm bolts broke off so it was still pushing the valve down but barely (the push rod and rocker arm were at a weird angle) its definitely not wet stacked cause i run it too hard for that. and thats whats so weird the truck passes every test (scan tool) with flying colors, no codes and all the sensors look good...thats why im thinking it is just an injector issue.
You may be right. Throw some 2's at it, if that ain't it, they'll help you find the problem
hey does beans have a payment plan or do you have to drop it all at once
lol no payment plan from Ryan.
hey what all injectors do you have...i saw a couple but do you carry them in the stage 2 range. also do you carry that line that runs from one oil rifle to the other on the other side...it equals out the pressure in the two oil rifles in the heads.
Dirty injectors
Dirty IPR screen Low oil pressure on the high side Low fuel pressure Contaminated oil just some random thoughs, hope you find it man!!! BTW, didn't you just get some injectors replaced under warranty???? |
HPX line is what you are talking about I think Turbodude. It ties the two oil hpo rails together, bout 30-40$
I got my high pressure oil line from black cloud and it was about 40 bucks. took a whole 10 minutes to install and took a bunch of shaking out of my motor. Smoothed it right out. I do not think that mine was shaking as violenty as you describe but it certainly cannot hurt. hope you figure it out.
