95 powerstroke icp sensor cracked can this cause the truck not to start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-23-2010, 05:35 PM Thread Starter
My icp sensor is cracked not at the actual sensor but where the wire connector neck connects to the sensor its self can this cause the truck to not start??
Forrider is offline
post #2 of 5 Old 06-23-2010, 05:42 PM
Shaking the Bush Boss
CHUCK's Avatar
bump up for ya.
It may, cause no start problems
Chuck
CHUCK is offline
post #3 of 5 Old 06-24-2010, 05:36 AM
ridiculously_necessary's Avatar
it may. unplug the sensor and try to start it. if it fires up its a bad sensor. they are supposed to default to a safe injection pressure when they are unplugged.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 5 Old 06-24-2010, 12:28 PM
JD3020's Avatar
Yep, if its bad and plugged in it will only start if you stand on the throttle, and it will die very easily. How do i know? I limped my truck home 10 through the ghetto when mine went out, and i didn't think about unplugging it. When i unplugged mine i had to give it a little throttle for it to start, but i believe that was partially caused by a bad IDM.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #5 of 5 Old 06-24-2010, 10:09 PM Thread Starter
Ok thanks for the info but the truck isn't getting any oil pressure either the oil pressure gauge use to go up to the middle when cranking then it would start it only took the gauge a sec to spring up but now when cranking it won't move at all and no start does anybody think its the hpop? Cause thats what I think and I would like to know because I called movers out at crestline and they have 2 complete engines without any parts missing and I would like to buy them or atleast get some parts off it like the hpop wire harnesses icp sensor and all that good stuff
Forrider is offline
