Front Diff - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-16-2007, 04:09 PM Thread Starter
Front Diff
Can somebody out there tell me how to drain the front diff on a '97, F250 PSD? I hate to sound dumb, but I can't find a drain plug or removable plate.
Thanks for any help, Floater
montanafloater is offline
post #2 of 7 Old 05-16-2007, 04:17 PM
Thats Mr. Oil Leak.....
MrJohnWayne's Avatar
Quoted: 5 Post(s)
probably just need to remove the diff cover. most dont have drain plugs.
John Wayne
Owner and Operator of the
REDNECK VALDEZ
You can find me on
MrJohnWayne is offline
post #3 of 7 Old 05-16-2007, 04:20 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
It has been a while since I worked on one of those, but I think the plug is between the ribs on the chunk. You may have to separate the chunk from the axle to drain it and re-fill it through the plug.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 7 Old 05-16-2007, 07:39 PM
7.3 tech, supporter
fordnut85's Avatar
Pipe is right, you have to seperate the 3rd member from the housing to drain, I pull the axles so I candrop the center section out and inspect it but if all you wanna do is change the fluid it can be done without pulling the axles. The fill plug should be on the front of the TTB where the diff cover would be on a solid axle truck.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #5 of 7 Old 05-16-2007, 10:01 PM
Stroked95's Avatar
Sooo I'm not sure now either. On a D60 front axel you can't just pop off the diff cover to change the fluid??
1995 Reg Cab F350
totaldieselperformance.comWildman Tuning
terminatorengineering.com Terminator Nation
wideopenperformance
Stroked95 is offline
post #6 of 7 Old 05-17-2007, 06:52 PM
7.3 tech, supporter
fordnut85's Avatar
You can on a D60 but I don't think his truck is a solid axle, it should have the TTB (twin traction beam) front axle, it is either a D44 or most likely the D50 the they are a little different that solid axles.
Duane
10k mod
Idle control mod
Tymar intake
post #7 of 7 Old 05-17-2007, 08:09 PM
Stroked95's Avatar
OOPS, sorry I missed that part. I didn't think there were any tricks to a straight axel.
1995 Reg Cab F350
wideopenperformance
