My truck SUCKS! - Ford Powerstroke Diesel Forum
Old 05-15-2007, 09:29 PM
My truck SUCKS!
You read that right. I have been driving my truck for a few days without my chip. It's almost unbearable to drive without it. It's really bad when you're stopped at a light next to (insert brand here) and you don't think you can beat them to the lane merg . Or for those times when you need to accelerate for "merging" purposes onto the interstate and you can't out accelerate those ricers. I miss my Wildman chip. I can't wait to get it back, it was good before without being tuned for big oil, so I can't wait to see the difference with it being tuned for it. Go ahead I dare you to pull your chip, and experience STOCK
Old 05-15-2007, 09:33 PM
Nuckin' Futz
Go ahead I dare you to pull your chip, and experience STOCK thats priceless...at least you didn't have to pull it cause you thought it was causing all the problems...so there is a potential of it being the problem meaning you don't get to put it back in....and yeah they are dogs stock.
Old 05-15-2007, 09:39 PM
I pulled my programmer for about 2 months and let my brother use it and the power loss sucked for the first week but after that I was I got use to it.
Old 05-15-2007, 10:06 PM
Send a message via Yahoo to worx
When I took my truck in for them to diagnose and rebuild the tranny recently, I went to the trouble of dumping the program back to stock to eliminate the tranny shift mods, so they could see what it was doing pure... I guess it did a little too much- they called and said the tranny was fine, the truck just had no power! I asked if they would reprogram it with the 100hp boost and try again... they called back later that day and said it was doing what I said, and that the power was back...
I can't imagine having to go stock... I had to use the shop's 07 250, which was not bad, but I miss my 7.3...
Old 05-15-2007, 10:11 PM
Thats the same reason why i took my programmer off but i got a new tranny for the 2nd time then blew out the reverse planetary gear after 5000 miles then got it rebuilt then 50 miles later my bumper to bumper warranty was up.
Old 05-16-2007, 03:08 AM
Rob Rob is offline
which programmer were you using to tear up your trannie like that?
Old 05-16-2007, 06:18 AM
Thats Mr. Oil Leak.....
I remind myself every once in a while and switch my ts to stock. Can't believe the difference with just the 50 setting.
Old 05-16-2007, 08:21 AM
I'm running the PPE Xcellerator programmer.
Old 05-16-2007, 08:24 AM
The Fat Mod
Sounds like you need an SCT
Old 05-16-2007, 11:10 AM
If you haven't had a PPE, you should try it out. You would say bye bye to your sct.
