fuel filter changed, and light still flickering on - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-11-2007, 02:43 PM Thread Starter
97_powerstroke77's Avatar
Question fuel filter changed, and light still flickering on
Hey all, I just changed my fuel filter and the light went out but within 10 minutes it came back on. It flickers and goes away when WOT. Can anyone help me here? Should I look at sensors or something?
1997 4 door 4x4 7.3 powerstroke auto cat delete, on 33's skins
2010 CrewCab FX4 Lariat
Edge Evo CTS Race
DPF & CAT delete 4" pipe from Turbo back
97_powerstroke77 is offline
post #2 of 9 Old 05-11-2007, 02:44 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Did you drain the fuel bowl when you changed it
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 9 Old 05-11-2007, 02:47 PM
Check the mesh screen in the side of the filter housing it may be clogged.
OLDTOM is offline
post #4 of 9 Old 05-12-2007, 07:44 AM Thread Starter
hmmmm
I have never drained the fuel bowl when changing the filter.
I will check the screen. I did not notice a screen in the filter canister. but I will check it too.
Thanks for the advice.
Edge Evo CTS Race
post #5 of 9 Old 05-12-2007, 02:36 PM
7.3 tech, supporter
fordnut85's Avatar
The screen he is refering to is between the fuel filter housing and the regulator, separate the two and you will see it, 99% of the time it is clogged.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #6 of 9 Old 05-14-2007, 02:39 PM Thread Starter
not sure I can tell where the screen might be. Sorry to sound stupid but where shold I look?
I have drained the housing. Is it at the bottom ofthe housing? need I remove the little clip? or is it somewheres else?
Edge Evo CTS Race
post #7 of 9 Old 05-14-2007, 02:55 PM
rankroddin250's Avatar
when you have the filter housing drained with no filter in it there is a hole on the right side (your right looking at it) it goes from the filter housing to that brass box on the side (BRASS BOX IS THE FUEL PREASURE REGULATOR) the screen is inside that hole you can clean the screen with q tips and an arosol can of seafoam from inside the filter housing. or the regulator can be removed from the filter housing for a more thurough cleaning of the screan but you must be verry careful because little parts can be lost in the intake valley if you drop them best way to keep from doing that is to place a rag under the regulator before taking it off
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #8 of 9 Old 05-14-2007, 03:08 PM Thread Starter
found it. Thanks again... that was it!
Edge Evo CTS Race
post #9 of 9 Old 05-14-2007, 04:00 PM
p.s. you should drain the housing every time you change the filter! reason being is it is full of any of the water that gets seperated from your fuel and the bigger particles that dont get sucked into your filter are just floating around in there! its the little yellow tab on the left side of the housing... changing the filter with out draingin the housing is like taking a shower and putting your dirty clothse back on
