dana 50 to 60 swap - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-28-2007, 01:36 PM Thread Starter
dana 50 to 60 swap
hey guys i have a dana 60 front axle out of a 91 f350 i am going to be puttin in my f250 but the gear ratios are differnt i was wondering if the dana 50 ring and pinion will fit i dont know much about ths sizes or this stuff and what will fit what so i figured i would ask someone that knows
thanks matt
1997 F250 Powerstroke
1995 800 Indy Storm
1988 5.0L Mustang
1987 YZ 125
1986 Chevy 4x4
1985 Honda 250SX
matt5liter is offline
post #2 of 6 Old 04-28-2007, 02:17 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I think they will, but not positive.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 6 Old 04-28-2007, 08:00 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
NO the 50 ring and pinion Do not interchange they are smaller
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 6 Old 04-29-2007, 12:31 PM
7.3 tech, supporter
fordnut85's Avatar
Quad is right, they dont interchange. D60's are pretty popular so it won't be hard to find the right ratio to match the rear. I have used randy's ring and pinion before and will swear by them from now on, awesome service.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #5 of 6 Old 04-29-2007, 12:33 PM
International Threat
Marty's Avatar
I wouldn't recommend ever taking gears out and resetting them in a different axle anyway. So even if they'd fit... I wouldn't do it.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #6 of 6 Old 04-29-2007, 05:37 PM
mech2161's Avatar
I've changed front 50 for a 50 and rear 10.5 for 10.5 both used with no problem at all. Now mind you I've broken a few but never due to install or fit problems. I use the same shim pack that I take out of the housing I'm reinstalling into.
Kevin
SPONSORED BY
Air Flow Systems
Terminator Engineering
DI Performance, South Bend Clutch
Discount Power Parts, Grand Rock
mech2161 is offline
