97 f350 7.3 Lift Pump Question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-20-2010, 07:28 AM Thread Starter
HUSKER POWER's Avatar
I am going on vacation about 2500 miles pulling a 13000 lb trailer, in 2 weeks and I bought a new lift pump that I am going to try and put in my self in hopes to save a little bit on fuel cost because mine is dripping. Questions, First does the weep hole leak more fuel running down the road verses at a idle in the driveway? Second I have never done this before and scared that I might make things worse if I attempt this myself. Third does the pump go completely out or is it just famous for leaking. Any suggestions are appreciated,Jeff
HUSKER POWER is offline
post #2 of 13 Old 03-22-2010, 07:05 AM
ridiculously_necessary's Avatar
they just get realyl weak and get to the point they dont provide enough pressure from what i can tell. as well as leak.
there are some good write ups aruond here on replacment. i believe there are some in the 7.3 tech section as well.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 13 Old 03-22-2010, 08:06 AM
Interior Guru
weareweird69's Avatar
Quoted: 105 Post(s)
Feedback Score: 3 reviews
Naturally it will leak more when its running down the road, its pumping more fuel.
Its not too hard, but time consuming, you need a 1 1/4" box end wrench to get the banjo bolt out, and you have to remove the fuel bowl and the fuel lines on it. Its not real hard, but more of a pain.
And yes, they just get weak, and begin to weep fuel. you cant see the weep hole, but you'll see fuel in the valley.
-Garrett
Too many projects. Too little time...
weareweird69 is offline
post #4 of 13 Old 03-22-2010, 02:40 PM
Chop's Avatar
Some guys will pull filter assembly and lift pump with hoses attached and yes it is a pain but satisfying.Take care when lifting pump,can be pryed up evenly and watch for the little push rod they always speak about.When I did mine the "rod" which came with the pump, was more like a small engine valve that rides the camshaft and thus operates the tandem pump With new pump in hand you will feel more confident
Chop is offline
post #5 of 13 Old 03-23-2010, 06:44 AM
97powerstroker's Avatar
Quoted: 14 Post(s)
im pretty sure its a 1 1/4 banjo bolt.the most important thing is when your pulling the pump out,the cam driven plunger on the bottom can slideout of the pump and fall in the engine.be very careful with this,it can be catastrophic if it happens.also youhave to be just as careful putting the new one back in.itcan be a pain to do with the turbo pedistol,mainlythat banjo bolt,you may have to mod the wrench a bit.goodluck>>>>>>brian
2002 F-250 7.3 auto CC/SB lariat 116k miles, 6.0 trans cooler the rest is stock.
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #6 of 13 Old 03-23-2010, 06:59 AM
Interior Guru
Quoted: 105 Post(s)
Yea, 1 1/4 Sorry.
-Garrett
post #7 of 13 Old 04-01-2010, 06:56 PM
CPD4thD's Avatar
What is it about this plunger that makes it so easy to fall off into the motor?
CPD4thD is offline
post #8 of 13 Old 04-09-2010, 06:21 PM
Quoted: 14 Post(s)
when you lift the pump out ,the plunger sometimes slide right out of the pump and can find its way around the camshaft into the engine.
post #9 of 13 Old 04-10-2010, 11:19 AM
lil o rinny's Avatar
Hey is there any way to know when the pump is getting weak? Mines leaking a little but dont really know if it is getting weak or not. Its not really leaking enough to change it yet, but it wouldnt hurt anyway. Thanks
~Anthony~
1997 Ford F-250 173000 miles
PSD auto 4:10 gears
4x4 reg cab
Originally Posted by alberta 7.3 View Post
I like my red interior, it's like I'm inside a vagina and I get to control where it goes.
lil o rinny is offline
post #10 of 13 Old 04-10-2010, 08:49 PM
Adam-Arc's Avatar
If it leaks it's weak. You're losing pressure to the injectors.
97 F350 CC 4x4 Auto Welding Rig
Steamfitters Local 475, Newark, NJ
IDM mod/Homemade CCV/10k/6637/3"dp/4" exhaust/no cat/muffler
Adam-Arc is offline
