Fuel leak - Ford Powerstroke Diesel Forum
Old 04-15-2007, 07:55 AM
Fuel leak
I have a 97 PSD just changed fuel filter and now have a small leak. Leak only occurs when I turn the engine off. Any ideas?
Old 04-15-2007, 11:14 AM
Where is it coming from?
Old 04-15-2007, 11:17 AM
duct tape & zip ties
usually leaks occur while everything is under pressure. As in when the truck is running not when the truck is shut off.
Old 04-15-2007, 11:28 AM
could be an injector pump depending on where it is coming from.
Old 04-15-2007, 11:58 AM
I don't know if the older ones are the same or not, but I had a leak that only showed up when the truck sat for a few hours (2000 F-350). Mine was the o-rings on the filter bowl drain.
-Aaron
Old 04-15-2007, 12:03 PM
I had the same problem but it was the mechanical feed pump behind the fuel bowl.
Old 04-15-2007, 06:58 PM
7.3 tech, supporter
Take a good look down into the valley of the motor and see if you can tell where it comes from, could be filter o-rings, the filter lid seal, fuel pump or you might not have got the water drain valve closed all the way.
Old 04-16-2007, 12:18 PM
Thanks for the response - I haven't had time to look to see where it is leaking from but I will take a look this weekend.
